Do water pump and timing chain during plenum install?
Old Dec 21, 2011 | 11:03 PM
dhvaughan's Avatar
dhvaughan
yes, you should replace timing chain and water pump while the top of the motor is stripped down.
my timing chain was shot at 125K with a ton of slack. timing chains don't usually break, and won't usually slip till 300K or so, but when they get a lot of slack it throws the timing out. also, my front seal was leaking.
my water pump was about $65-70. simple cloyes timing set was about $40. you'll need to borrow/rent a harmonic balance puller. set it up for the puller to push on the crank bolt, not the precious threads.
https://dodgeforum.com/forum/2nd-gen...ater-pump.html
Old Dec 22, 2011 | 09:12 AM
Adobedude's Avatar
Adobedude
Originally Posted by NyghtProwler
timing chain breaks......pistons and valves are no longer in sync......kaboom!!!!
Kaboom more than once....
Old Dec 22, 2011 | 11:07 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You might want to include O2 sensors too.
I only have 1 upstream of cat and 1 downstream.
I'm hitting up the Denso ones.
Old Dec 22, 2011 | 11:52 AM
kejobe's Avatar
kejobe
I got NTK o2s. A lot cheaper. At least around me.
Old Dec 22, 2011 | 03:53 PM
SilverSS's Avatar
SilverSS
cheapest O2's I found were on Amazon and I think a little under $30 . Just bought some Denso O2's for my TA @ $26.00 each.
Old Dec 22, 2011 | 04:04 PM
kejobe's Avatar
kejobe
I got mine at advance auto. NTKs are $30-$50 and Densos are $50-$75.
