Rear Carrier
Old Aug 2, 2005 | 06:37 PM
allmopar's Avatar
allmopar
Default Rear Carrier
My '01 1500 had recent issues with the speed sensor. Found out the reason the spped sensor was destroyed - a washer broke so the shrapnel destroyed the sensor. Went to a mechanic and apparently the washer itself is not available. I'm being told that I need to replace the WHOLE CARRIER - just to get a washer!![X(]. This translates to about $600 for the part which is only avail from the dealer. Sorry the description is vague but I'm trying to repeat what the mechanic said (not what I know - because I don't). Anyone else have this problem, or any suggestions? I can't believe that I'm about to spend $600 + LABOR - for a WASHER
Old Aug 3, 2005 | 03:24 AM
HuntinHanson's Avatar
HuntinHanson
Default RE: Rear Carrier
Couldnt you go to a junk yard and get the part? even if you had to get the whole axel for your mechanic to get the washer out...still wouldnt be $600. Thats just rediculous. There has to be something else you can do....
