How to easily replace the by pass hose?
Old Dec 23, 2011 | 09:41 PM
chadhager03's Avatar
chadhager03
Default How to easily replace the by pass hose?
I replaced my plenum and it went surprisingly well. Truck started great and idled great. The only problem is there is a noticeable leak on the bypass hose is there any easy way to fix this without removing the accessory Bracket? Thanks
Old Dec 23, 2011 | 10:00 PM
Sheriff420's Avatar
Sheriff420
Nope. The accessory bracket is pretty easy to pull off though.
The new hose might be easier to slip on if you put it in really hot water for a couple minutes first.
Old Dec 23, 2011 | 10:04 PM
Ecoastmotion's Avatar
Ecoastmotion
Yeah it is possible to do it, ive done it before. Bit of a chore with all of that Mopar engineering in the way but its doable. Hardest part is getting the bypass hose clamp on the top part of the hose that runs into the intake. Get creative with some pliers and a screwdriver and you should be fine.
Old Dec 23, 2011 | 10:24 PM
chadhager03
Well I replaced the bypass hose but I think I might have forgot to put the top hose clamp back on.......... Alright thanks, the accessory bracket isn't that hard I was just hoping for some easier way lol
