Fuel pump?
Old Dec 24, 2011 | 03:20 AM
ramhead101's Avatar
ramhead101
Default Fuel pump?
Hi i have a 1997 dodge ram 1500 slt 5.9 liter. Since i got the truck its been had to start sometimes i gotta hold the key for a few seconds for it to actually start esp in the morning well today i was coming to a stop light and my truck stalled i tried starting it but nothing all it did was turn over. I thought my guage went bad so i had my girlfriend bring me a gallon of gas i poured it in tried starting nothing but turning over so i went under the truck banged the gas tank and it started it but then stalled again. Aslong as i keep hittin the gas tank the truck keeps running once i stop it shuts off. All this leads to the fuel pump being bad right? If so around how much is a fuel pump thank you
Old Dec 24, 2011 | 07:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Most likely bad pump. Check the electrical connector on top first though. And for a new pump, check out Rock Auto. Don't cheap out on it. Also use the discount code from the thread in the general discussion section.
Old Dec 24, 2011 | 10:08 AM
ramhead101's Avatar
ramhead101
Alright ill check that out thank you
Old Dec 24, 2011 | 10:18 AM
zman17's Avatar
zman17
No prob, happy holidays.
Old Dec 24, 2011 | 11:08 AM
P1NKST@FF's Avatar
P1NKST@FF
I'm on my 4th fuel pump since owning my truck so yea don't cheap out on it. Also that nut on top of the tank is a bitch to get off, my remedy is a cheap strap wrench for oil filters, makes the job soooo much easier
Old Dec 26, 2011 | 03:40 PM
ramhead101's Avatar
ramhead101
I ordered the bosch fuel pump it should be here tomorrow the gas tank is already out of the truck and the fuel pump is already out of the gas tank with the gas tank out i decided to sand down and rino line the bottom of my truck to prevent rust so now im jus waiting on the pump
Old Dec 26, 2011 | 03:52 PM
zman17's Avatar
zman17
Good call. Also, Check out the brake and fuel lines that are running by the tank for rot. A lot easier to replace while the tank is down.
