lights out
Old Dec 29, 2011 | 07:59 AM
yellowtruck's Avatar
yellowtruck
Default lights out
If i am driving with my high beams on my lights will periodically just shut off completely. It doesnt do this when low beams are on? Any suggestions?
Matt
Old Dec 29, 2011 | 09:12 AM
Augiedoggy's Avatar
Augiedoggy
Matt
Hi/lo beam switch is going bad? I would try spraying contact cleaner into it first (With the truck and lights off of course) as well as the headlight switch since it still may be making poor contact and doesnt cut out until their is additional draw from the highbeams. If that dont work replacing it? after checking the condition of any fuses involved and relays but I dont believe our trucks use relays for the headlights. Also Check the ground! I had a similar issue a few years ago with regular beams and it was a corroded ground connection by the headlights
Old Dec 29, 2011 | 10:27 AM
botta's Avatar
botta
light switch is going out, mine only worked as high beams, and would flicker on and off on low beams.. and im talking about the light switch on the dash, that turn the light on.
