engine trouble
Old Dec 31, 2011 | 06:06 PM
Ram 1500 v6's Avatar
Ram 1500 v6
Default engine trouble
my truck started to sputter and almost dies today and then it comes back and iddles around 2,500 rpm then slowly drops down and as soon as u touch thge gas it iddle right back up .. wondering what some possible solutions or problems could
Old Dec 31, 2011 | 06:10 PM
UnregisteredUser's Avatar
UnregisteredUser
Sounds like a sticky IAC is the most likely culprit. Somewhere hereabouts there's a thread about cleaning those.
Old Dec 31, 2011 | 06:59 PM
Tparkin's Avatar
Tparkin
seems like I remember mine doing that when I had a vac leak in one of the hoses that goes from the canister on the frame to the solenoid under the hood. If I remember correctly, I replaced the IAC first and kept the same symptoms.
Old Dec 31, 2011 | 07:51 PM
Ram 1500 v6
when you IAC what does that mean
Old Dec 31, 2011 | 07:59 PM
UnregisteredUser
Idle Air Controller. It's a solenoid valve on the back of the throttle body -- like a sensor, only it doesn't sense anything at all.
All it takes to clean the thing is some sensor safe cleaner (MAF cleaner in a spray can), some paper towels, cotton swabs, and a T-25 driver. Unless of course you tear the o-ring, then you'll have to replace it. It's cheap and easy, doesn't take too long unless you drop a screw, and worth a shot. I'm pretty sure there's a DIY in the FAQ/DIY section that's worth a quick read, anyway.
Old Dec 31, 2011 | 10:37 PM
gdstock's Avatar
gdstock
And disconnect the battery before you start!
