Oil Leak?
Old Jan 2, 2012 | 06:11 PM
de8212's Avatar
de8212
Default Oil Leak?
My 99 Ram leaks a few drops of oil every now and then. Got up under it a few months back and snugged down on all the bolts around the oil pan(I think that's what it's called). Seemed to work for a while but it started doing it again. Isn't there a gasket I can maybe replace to see if that stops it?
If so, can someone tell me how/what all I need to do it?
Thanks.
Old Jan 2, 2012 | 06:18 PM
kejobe's Avatar
kejobe
First of all, are you sure the leak is from the oil pan? Best thing to do is clean the motor and keep an eye on it to verify where it's coming from. Then you can go from there.
If you are sure it's from the pan itself, just get a new gasket, and follow the first part of this: http://www.pavementsucks.com/tech-article-31.html
