Rear Sway Bar for 98 Ram 2500
Old Jan 8, 2012 | 09:53 PM
Bigbluedodge's Avatar
Bigbluedodge
Default Rear Sway Bar for 98 Ram 2500
I am wanting to add a rear sway bar to my 1998 Ram 2500 pickup. Were there certain series that came stock with one? Was looking to find one at a salvage yard and wasn't sure which trucks to look under. Thanks for your help!!
Old Jan 9, 2012 | 12:01 AM
gdstock's Avatar
gdstock
Don't know...but if you check the parts manual in the FAQ/DIY section it should list what models would have them from the factory.
Old Jan 9, 2012 | 08:37 AM
Ugly1's Avatar
Ugly1
I found one on a 2wd diesel that I couldn't make it fit without modding. I think it may be that the 2wd and 4wd rear sway bars are slightly different?? Don't know for sure but there at least a couple different aftermarket options. I like the one I ended up with since it can accommodate my lift which the stock one wouldn't have done without a couple adapter pieces. There is a beefier one than the Hellwig one I bought, Roadmaster I think is the brand, but the Hellwig is beefier than the stock ones are.
