transmission light on
Old Jan 12, 2012 | 02:33 PM
firemanjim70's Avatar
firemanjim70
Default transmission light on
hello new here can anyone help me I have a 2001 quad cab 1500 4x4 and my tranny light just came on today fliud is full.
rhank you jim
Old Jan 12, 2012 | 03:21 PM
bjr1a's Avatar
bjr1a
Did you check the fluid level in neutral? ....FLuid level will not check correctly in the park position...
Old Jan 12, 2012 | 03:26 PM
firemanjim70
i will give that a try
Old Jan 12, 2012 | 03:28 PM
drewactual's Avatar
drewactual
your transmission light is closely related to your o/d off light.. when you see the o/d disengage, look for a place to stop right then and there.. when you see the trans light come on, it's game over for the fluid..
heat destroys atf+4 in short order.. burnt atf+4 ruins transmissions in short order.
you need to drop the pan and let it drain for a good long time.. it would be wise to disconnect the cooling lines, and flush out the cooler.. while you're at it delete the check valve in the high pressure line (DIY in FAQ section).. make sure everything is nice and clean.. replace internal filter.. use new gasket if you don't have a reusable one... refill.. hope for the best..
DO NOT FLUSH THE TRANSMISSION
DO NOT USE ANYTHING BUT ATF+4
my first guess is the check valve clogged, or the heat exchange clogged, or both.. heat is a bad thing dude..
Old Jan 12, 2012 | 03:44 PM
firemanjim70
thanks for the information. will have to give that try
Old Jan 12, 2012 | 06:02 PM
dhvaughan's Avatar
dhvaughan
if that doesn't work, browse through this thread and start saving your money.
https://dodgeforum.com/forum/2nd-gen...info-only.html
