Front Driveshaft!!!!!!!
Old Aug 5, 2005 | 07:03 PM
crusher135's Avatar
crusher135
Default Front Driveshaft!!!!!!!
this ****er took out my driveshaft to fix the tranny and broke a bolt but anyhow he didnt fix it so i had to anyhow when i put the driveshaft back in does it have to line up to anything? because in the book it says to mark it when u take it out well this ******* didnt wat should i do?
Old Aug 13, 2005 | 03:12 AM
Trippen's Avatar
Trippen
Default RE: Front Driveshaft!!!!!!!
If your going from the flat mounts with the 4 bolts on the axel to the flat mount on the transfercase you should be ok. Most times when you remove it they say to mark it is for the balancing it had...At least this has been my experiance. And it never has made a differance what way it went in.
