What's the difference ?
Old Jan 19, 2012 | 11:14 PM
DogeRamGuy1993's Avatar
DogeRamGuy1993
Default What's the difference ?
285/75/16 vs. 295/75/16
what is the difference and if i can fit 285's then could i fit 295's ?
Old Jan 19, 2012 | 11:22 PM
dhvaughan's Avatar
dhvaughan
here's one of many tire size calculators.
http://www.1010tires.com/tiresizecalculator.asp
just off the top of my head, the 295's are 10mm wider (about 3/8") and a smidgen taller. they should fit fine. some people are able to fit 305-315. if you get rubbing at full turn, adjust the turn stops on the knuckle.
Old Jan 19, 2012 | 11:32 PM
DogeRamGuy1993
well my original plan was to go with 315/75/16 on my oem rims but someone told me that those tire wont fit on my rim?
Old Jan 20, 2012 | 01:33 AM
mstephen89's Avatar
mstephen89
315/75/16 will fit on your oem rims, although they really need a wider wheel. but they would fit and with a 2.5" spacer in the front, they probably would not rub either
Old Jan 20, 2012 | 02:10 AM
Wombat Ranger's Avatar
Wombat Ranger
Whatever you do, POST PICTURES!!!!
Old Jan 20, 2012 | 02:35 AM
merc225hp's Avatar
merc225hp
To see what size tire fits what size rim the best bet is to go to the tire manufactures web site and see what the recommend rim width is. In most to all cases it's a 8.5 inch wide rim for a 315 or 12.50.
