Quick Trans Pan Seal
Old Jan 21, 2012 | 06:59 PM
EFS463's Avatar
EFS463
Default Quick Trans Pan Seal
Trans pan has develpoed a little leak that will drip a couple drops overnight. I dont exactly have the time to drop the pan this weekend and I wanted to get by another week or two. Is there any way to give it a quick seal on the outside thatll keep it from dripping for a week or so
Old Jan 21, 2012 | 07:14 PM
stewie01's Avatar
stewie01
I wouldn't push it too long, dropping the pan and changing out the gasket and filter is cheap, fluid to refill can cost around $50 or so depending on what brand and how much you get...
A small leak can turn into a big leak in hurry. I was supposed to be in Virginia this weekend for my baby sister's 18th birthday, a loose/leaky TCC/OD Solenoid Assembly put that trip on hold.....
Old Jan 21, 2012 | 08:11 PM
dhvaughan's Avatar
dhvaughan
a few drops out of 12 quarts won't be missed. just keep it full and you'll be fine.
no quick fix that will work, but you might re-snug the pan bolts and slow it down a little. don't break them off, as torque spec is light, something like 15-20 pounds.
Old Jan 21, 2012 | 08:36 PM
stewie01's Avatar
stewie01
13ft lbs
