2wd lift question
Old Jan 24, 2012 | 01:42 PM
97_ram1500's Avatar
97_ram1500
cause the more i think about it the less i want to change gears. im thinking if i did the 2" coil spacers, 3" spindles, and a 3" block that would fix the sag plus have a level 3" lift so from what i see in my head 33s would look great without the stuffed look or the need bigger tires look.
Old Jan 24, 2012 | 03:48 PM
redheadhunter21's Avatar
redheadhunter21
35's did not fit my truck with 5.5" of lift. The tires where 315/75/16 on 16x10 rims. The rims have 5" bs and I run a 1" spacer so they have 4" of bs.
Now if you run a 9" wide rim and jump up to a 17" rim with more bs you should be able to clear them.
Bs is backspacing
Old Jan 25, 2012 | 09:50 AM
97_ram1500's Avatar
97_ram1500
Yeah I may just go with the 5/3 on 33s. I like room to stuff the tires just hoping it won't make them look too small. Does it sound right or should I go with 34s?
Old Jan 25, 2012 | 10:05 AM
Augiedoggy's Avatar
Augiedoggy
Do you realize how much its going to effect power and mpg to put 33+ tires on there without changing gears? not to mention the fact that it will shorten transmission life....I would make that a priority.
Just so we are all on the same page.... A LOT of people go down this road ignoring or unaware of this and once its lifted they realize what a dog it becomes to drive and how bad the gas mileage gets and then turn around and try to sell it...and in your case it would make it a hard sell... Take this as opinion but I dont see an underpowered overworked 2wd truck made to look like 4wd as a hot seller...
The plus side is you only have one axle to worry about changing the gears in...
I should add that I made a similar mistake with a jeep wrangler I had...I bought it with 31" tires and stock 4.10 gears (4 banger) when I put 32" tires on it I could no longer even use 5th gear properly...It wasnt until I put close to stock sized 28" snow tires on it that I realized just how much power and gas mileage I was losing with the bigger wheels.... I then had 4.56 gears installed and gained most of that power and mpg back. HUGE difference... It was a stick so I could only imagine how much worse it wouldhave been for an auto...
Old Jan 25, 2012 | 02:01 PM
redheadhunter21
Yeah you lose power with 33's but it's not the end of the world, gas mileage I never noticed a change.....but when you get 10mpg regardless of how you drive I wasnt worried.
Sct tuner will make up for tire change(power loss) for a little less than gears, but still more wear on truck parts.
But 4.10 gears and 33's make for some fun
Old Jan 25, 2012 | 02:10 PM
dlyter09's Avatar
dlyter09
I run 4.10s with 33's right now and I have had 35's on there and I would stick with the 4.10s. anything over 35's though I would be swapping in 4.56's or even 4.88s. Thats just my 2 cents though.
Old Jan 25, 2012 | 10:10 PM
97_ram1500's Avatar
97_ram1500
thanks for the opinion but its gonna be on 33s. ive lifted my fair share of 2wds so i think i can handle a slight power loss unless i felt like making engine mods to make up for it
Old Jan 26, 2012 | 06:41 PM
EndIsNear's Avatar
EndIsNear
Here's the pic of my lift like I promised.
Old Aug 9, 2012 | 03:58 PM
Freehaf972500's Avatar
Freehaf972500
I've got a 97 2500 2wd all stock but I wanna put a small lift on it and throw some 33s or even 35s on it, and I read above that I should swap gears to atleast 410s? Wondering what you guys are using for the front lift? I kinda wanna use a 3" body lift and maybe some small blocks in the rear?
Old Aug 10, 2012 | 07:13 AM
97_ram1500's Avatar
97_ram1500
You can do 3 inch spindles and 2 inch blocks. Or 2.5 coils and 1.75 shackles. Both will fit 33s in most cases. Going to 4.10s is advised but i havent done it yet and ive felt no difference. Im running the 2.5/1.75
