94 ram cat question
I have a dual exhaus system on my truck it's like a flow master knock off from my local shop, but my cats leakin now and I get a random check engine lite since it started leaking, and it has random stall issues after revving, an I want to save myself the 350$ can I just cut it off and put a section of pipe in, I know it's not good for etest and all but will it set codes or run rough? Is there any way to rig up the o2 sensors? Thanks
Originally Posted by Nortzy
(Post 2704410)
You will likely run rich if you weld in a pipe and do the fouler trick... better to just do it right you may even get better performance since the heat from a working cat helps scavenging effect. do a search on removing cat or bypassing cat... this gets asked every other day lots of info on it. |
A 94 only has one o2 sensor. You can gut it and the truck will run the same. Ive had mine gutted for over 5k miles, it improved performance and she purrs like a kitten.
Oh and I have no codes.
Ok thanks guys, and I tried the search but on the mobile app it brought up random stuff, I'll just go with a high flow, I'd punch mine clean but it's got a bad leak not worth welding
Originally Posted by SpencerS
(Post 2704443)
I've seen some people just clean the cats when they plug... http://www.youtube.com/watch?v=5icTmYItwiE http://www.youtube.com/watch?v=g5BSwI0JNQc |
has the plenum been checked also? No sense in spending money on a cat, just to have it get clogged.
