heli coil question
so i need to put a heli coil in a hole for an oil pan bolt. What might happen if I dont drop the pan to do it? There shouldnt be any shavings that get through into the oil and I could change the oil right after. So I'm not sure I see that I absolutely HAVE to remove the oil pan in order to do it. I could be missing something though?
yep metal chips in motors is bad jew jew. if you can have someone hold a vacuum near your drill while doing it. if not you could magnatize the bit and clean it often as you drill it. very important to drill very straight and hold diameter when doing this. you dont have many options when your done if the hole isnt correct. maybe start small and step drill size up as you go? gotta be on center of origanal location to match pan too.
good luck and happy machining.
