What was the reason for changing the sensor and solenoid to begin with? Was there an issue or just preventive maintenance for old parts?
Originally Posted by PapaG
(Post 2714215)
Good example of keeping things in the same thread. ;) |
(Post 2714215)
Originally Posted by zman17
(Post 2714207)
Probably not, if it wasn't touched previously. But I'd check it anyway. The factory adjustment can be found in this thread. https://dodgeforum.com/forum/2nd-gen...-in-trans.html
And if you wish to fool around with it any further, you can do so in this manner. http://www.bionicdodge.com/Download/...Adjustment.pdf |
TV cable can need adjusting for several reasons, including normal wear and tear, incidental slippin in bracket, and variations in wear in tranny.
Also, if speed sensor is not correct, it will effect shift points ad PCM controls this. Need to change it out and get rid of red light on dash. Eliminate any known problems that may mask other probvlems..... |
Originally Posted by gdstock
(Post 2714256)
(Post 2714219)
Originally Posted by blackbeasst
(Post 2714266)
yeah i guess i need to grab one. is it not odd that with the same bad speed sensor (supposedly), it should shift at the same points it did before we replaced the gov sensor/solenoid and bands?
(Post 2714255)
well i noticed that the tranny was acting up where sometimes it would jerk around in first, long shift times, etc. so i took it to a guy and he hooked his machine up and before we drove it showed me what it was supposed to register. well it was all over the map so we decided to go ahead and replace them as well as tighten the bands and change the fluid filter.
just boggles my mind that if it wasn't touched that it would change it in any manner |
aight, so in the 30 degree cold this morning with no abs/brake lights on it shifts like a champ around 23-2500 rpms. so all signs are pointing to the speed sensor messing with it yesterday when i picked it up.
so are speed sensors speed sensors or is there a better one compared to others? this one suffice? ok after looking around it seems that if i have 4 wheel abs that i have 2 sensors on the front wheels. how can i tell if i have 4 wheel abs? |
Look at the front wheels. If there is a wire going to them, you have 4wal.
