98 1500 5.9 V8 won't idle properly when warm
Old Feb 15, 2012 | 06:59 PM
DukeCityOffRoad's Avatar
DukeCityOffRoad
Default 98 1500 5.9 V8 won't idle properly when warm
Okay so my truck will start perfectly when it's cold but after it's warm it will start up but won't idle it just dies right away it will stay on if I put my foot on the gas and put up the RPMS it stays on if indo that for awhile it will idle fine. The only thing is the idle will just kinda move up and down a lot
Old Feb 15, 2012 | 07:08 PM
P1NKST@FF's Avatar
P1NKST@FF
Sounds like a dirty iac valve, idle air control and since it only costs the value of a can of carb cleaner I'd start there. I think there's a thread on how to properly do it.
On a side note are you in Albuquerque?
Old Feb 15, 2012 | 07:11 PM
DukeCityOffRoad
I tried some fuel injector cleaner that didnt seem to help I'll try the carb cleaner and yes I am well Rio now
Old Feb 15, 2012 | 07:15 PM
P1NKST@FF's Avatar
P1NKST@FF
I'm on the base, I can't remember if it's a dedicated thread or just a single post but it should come up in a search, I remember the just of it and know my way around the throttle body if you want help you could pm me here for a hand
Old Feb 15, 2012 | 07:20 PM
DukeCityOffRoad
Thanks for your I'll look and if I need some help I'll messagebyou
Old Feb 15, 2012 | 07:40 PM
Ham Bone's Avatar
Ham Bone
I had that exct problen happen after my battery died. Put a new battery in and it fixed the problem.
Just saying
P1NKST@FF's Avatar
P1NKST@FF
Good luck with fix
Old Feb 15, 2012 | 08:20 PM
gdstock's Avatar
gdstock
To get it clean, you need to remove it.
Here ya go: https://dodgeforum.com/forum/dodge-r...ighlight=Clean
Old Feb 15, 2012 | 08:24 PM
DukeCityOffRoad
Thanks I couldn't find a link to take off the throttle body that should help a lot
Old Feb 15, 2012 | 08:37 PM
gdstock's Avatar
gdstock
TB is pretty easy.
From the FAQ/DIY section:
2nd Generation Dodge Ram Service Manuals
2nd Generation Dodge Ram Parts Manuals
