best gas saver for my truck
Old Feb 23, 2012 | 10:40 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by dhvaughan
don't get a hypertech, they're third rate. if you really have to have it i've got one for an 01 i'll sell you cheap. if you want a tuner - get a superchips or SCT.
for best mpg - fix plenum, cat, replace timing chain, tune up, replace o2 sensors, modest all terrain tires to 265 or 285 max, avoid mudders, avoid lift. mild tune and drive like grandma. don't expect more than 15-16 mpg.
+1 very well said...
Old Feb 23, 2012 | 11:33 PM
jclark1287's Avatar
jclark1287
im getting like 10-11 mpg now ive got a new hughes plenum new plugs wires cap rotor new cherry bomb cat new 285/75/16 wrangler duratracs pretty un-aggressive new 3.92 gears i dont really have to have a tuner just looking for something like that or an intake to give me a couple more mpg for under 500 bucks 02 sensors are next on my list to do
Old Feb 23, 2012 | 11:43 PM
Augiedoggy's Avatar
Augiedoggy
your averaging the norm for your setup.... there are no real magic mods to get results... you coulds always grind the air horns off of the throttle body, that helps boost airflow and performance at the cost of slightly louder air intake....or buy a bored out 50mm one...I have a CAI and honestly I noticed no real improvement over the 14x3 round one the PO had on it except its not as loud.
some people claim to gain 2-3 mpg in the jeep forums with the 5.2 and bosch "703" injectors which are the newer style and spray a better atomized pattern instead of a jet of fuel...you need to have the fuel sync readjusted afterwards...I just did this mod myself but the truck has been out of commision with a cracked pacesetter header and a misfire to fix so I cant comment on results yet. and you might have gotten better mpg's by going with 4.10 gears which are closer to stock ratio for your tire size...
Old Feb 24, 2012 | 12:14 AM
lastrights's Avatar
lastrights
Sct would be a bang for the buck !
Old Feb 24, 2012 | 01:22 AM
jclark1287's Avatar
jclark1287
i was looking for sct but cant find a good place to get one any suggestions?
Old Feb 24, 2012 | 02:02 AM
CPTAFW163's Avatar
CPTAFW163
Also, if you are city driving, take your truck out of OD. I get to 40 MPH in only a half mile of my 3.5 mile commute. THe rest is avoiding pedestrians, stoplights/signs and getting stuck behind buses.
I switched to taking OD off and I gained .8 MPG over the course of a week.
Old Feb 24, 2012 | 02:29 AM
jclark1287's Avatar
jclark1287
i would do that but i do like 70-75 on the way to work and back home
Old Feb 24, 2012 | 04:17 AM
kejobe's Avatar
kejobe
http://www.hemifevertuning.com/Produ...Code=SCT%2DCan
Old Feb 24, 2012 | 05:05 AM
mj23polaris's Avatar
mj23polaris
Best way to save gas, drive like your trans is broke
Old Feb 24, 2012 | 07:21 AM
dhvaughan's Avatar
dhvaughan
slow down to 55-60 and you'll gain 2 mpg
