Head lights not working
Old Feb 27, 2012 | 07:50 PM
spanishgrass's Avatar
spanishgrass
Default Head lights not working
98 V6 automatic, no AC, just your basic Van. Very reliable, 235,000 miles on this vehicle , still gets 23 miles per gallon. This morning, I turned on the lights to leave for work and had no headlights. All other lights are working. I checked all fuses in both the interior box and engine compartment. Funny thing tho. There is no listing in either box for a fuse for headlights. I removed every fuse and all are good. Is there an inline fuse somewhere?
Old Feb 27, 2012 | 07:55 PM
P1NKST@FF's Avatar
P1NKST@FF
It could be your switch, try playing with it, tap it in busts hair when you turn on the lights and see if you can get them to come on. Mine went bad, then went back to working, then Tryed to burn the truck down! May not be the problem but that's my $.02
Old Feb 28, 2012 | 07:01 PM
spanishgrass
Default Thanks
Thanks for the tip. I removed the switch and sure enough it was gummed up with dust and years of grime. I blew it out and wiped it as best I could. Lights now working. I'll spray it with some electrical cleaner and hopefully it will go another 200, 000. Thanks again.
Any idea why rule #8 is posted in my original post.
Old Feb 28, 2012 | 07:04 PM
P1NKST@FF's Avatar
P1NKST@FF
No clue about rule #8 glad you fixed it though, it didn't look like it was gettin hot or anything?
