anyone running traction bars???
if so did it really help found these might just get but idk if they work as i have issues with getting off the line without spinning like crazy!
http://www.summitracing.com/parts/TFY-30997/?rtype=10
I could see those working but 2 things, first those things are awfully scrawny, and 2 for the best effect they would need to mount to the axle housing itself, not the leaf springs. By design our axles have some wrap to them. And mounting a set of traction bars to the axle will eliminate this. They won't stop you from losing traction and spinning out though, if you want better launches the keep some weight secured in the bed, preferably close to the tailgate
Traction bars eliminate wheel hop and twisting. Unless your wheels are jumping upon launch, traction bars wont net you more traction with burnouts. They keep the wheels planted and prevent axle wrap, but you'll probably burnout nonetheless. Like stated, weight will gain your more rear end traction...
