fluids question!
Old Mar 5, 2012 | 11:01 PM
offroadjosh's Avatar
offroadjosh
Default fluids question!
Alright yes i did search but wanted to mkae sure my 96 was the same..
changing the tranny fluid and the t-case
rounding up need 2gallons total? roughly 3pints for tcase and 5qts for drain and fill of tranny? atf 4 of course..?
then front axle? 5pints of 75-140synthetic
also doing filter and adding tranny temp gauge.
Old Mar 6, 2012 | 12:49 AM
SilverSS's Avatar
SilverSS
Sorry mine is a 2wd so not sure about the t case or front axle but when I changed my trans fluid it took closer to 7 quarts so you might want to have a little extra.
Old Mar 6, 2012 | 01:00 AM
95RAM360's Avatar
95RAM360
transfer case takes around 1.2 quarts (well mine did)
Tranny- 5 quarts
Front diff-2 1/2 quarts
Rear diff- about 3 quarts
i put 80w90 in the front and rear...never had a problem, and my trucks at 225K+
Old Mar 6, 2012 | 01:30 AM
offroadjosh
thanks! Hey 95ram your still alive! Hows it been going? Hows the truck? Work? Maine now right?
