Replaced Head, running rough
Old Mar 20, 2012 | 10:27 PM
absoluthidy's Avatar
absoluthidy
thanks, Chad & Sam. I'll double check.
Old Mar 21, 2012 | 12:48 PM
absoluthidy
took it for a drive today... the heater core or the blower motor is most definitely burnt up. smoke coming from a/c vents smells burnt.
changed out the plastic vacuum line and double checked everything... the truck doesn't shake, and maintains rpm's.
Took it for a drive and it ran well enough for me to believe that the noise i'm hearing is a leak at the exhaust manifold and when I think of my 89 Jeep Cherokee... it had the same sound, and it was because the gasket on the manifold burned off.
so I pulled it off and lo and behold... a broken bolt. time to find my EZ-out and pickup some grade 8's.
thanks for your help, everyone. I truly do appreciate it. Here's a pic of my truck...
If it wasn't for how good this truck has been to me, I'd probably just have sold it by now. I just can't seem to let her go.
Old Mar 21, 2012 | 10:33 PM
johnnyjaws98's Avatar
johnnyjaws98
what you changed CRACKED HEADS did it over heat? heat WILL destory a motor everything gos bad after a overheat
