i am a dumba$$ center chunk caps
Old Mar 22, 2012 | 09:40 AM
dipsherry's Avatar
dipsherry
Default i am a dumba$$ center chunk caps
So got front end almost back together and i realized i didnt mark the caps for the center chunk. So i noticed they had differnt markings. so my question is who is in need of a diff fluid change. i will paypal you the $$$ for fluid and a new gasket. If you can pull your front cover and take a pic of the caps for me i would love you forever. thanks guys this is my last part then she will be ready to play agian
Old Mar 22, 2012 | 10:08 AM
Sheriff420's Avatar
Sheriff420
Your sig says 1500 so I assume a D44. If that is the case, how are the steering knuckles/hubs holding up to those 37 inch tires?
Old Mar 22, 2012 | 02:33 PM
dipsherry's Avatar
dipsherry
sheriff thank you so much.....i broke my passenger axle and bent my knuckle. thats what started this whole locker thing. i got custom made chromolly shafts made and fabbed up some guessets to hopefully save this thing till i find a dana 60
Old Mar 22, 2012 | 03:03 PM
dipsherry's Avatar
dipsherry
this is my temporary fix for the knuckles.
dont mind the welded in ball joint not my dooing grinding them off and going to properly tack weld them in tonight
Old Mar 22, 2012 | 03:05 PM
dipsherry's Avatar
dipsherry
i found alot of jeep guys run guessets to tighten up the c so i figured i would fab something up
Old Mar 22, 2012 | 04:11 PM
Sheriff420's Avatar
Sheriff420
You should keep an eye on tread depth on the inside of that tire and compare it to the outside to make sure your camber is close enough to what it should be to avoid chewing it up. You might have to do a little bending of the knuckle (if it's even possible) after getting it back together.
I took those pictures back when I had to change my axle seals. I wanted to make sure I would put the caps back in right.
