drivers door hinge
Old Mar 25, 2012 | 05:24 PM
clownshoes67's Avatar
clownshoes67
New Member
Default drivers door hinge
I purchased new door hinges for my sons dodge ram. I have looked all over the internet on the best way to remove the hidden bolt. Can someone steer me in the right direction? I have reached my hand under the dash and cannot find a way to get to it. Do I need to remove any panels, or remove the parking brake mechanism? Can someone tell me what size bolt this is so if I do happen to get to it I will be prepared. This is the upper hinge I am referring to.
Old Mar 25, 2012 | 06:44 PM
kejobe's Avatar
kejobe
Honestly, iirc, the dash needs to be loosened and moved/removed to reach it. Whats wrong with the ones on there now? There are hinge pin kits available.
Old Mar 25, 2012 | 09:54 PM
plott hound's Avatar
plott hound
grab a hinge pin kit from LMC truck.sweet and painless fix.
Old Mar 26, 2012 | 09:59 AM
IHfarmer3339's Avatar
IHfarmer3339
Ya and only like $5 at advanced auto
Old Mar 26, 2012 | 04:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And there is a DIY in the FAQ/DIY section to replace just the pins. Of course, the OP already bought the whole hinge. SO, the FAQ/DIY section also has FSM's that can be downloaded.
Old Mar 26, 2012 | 04:47 PM
brewman's Avatar
brewman
If you've done it before you can pull the dash in about 45 minutes, but if you haven't may take a couple hours.
Old Mar 26, 2012 | 05:45 PM
peshewa's Avatar
peshewa
Mine has a male torx end & was removable with a female torx socket from the hinge area. If you can post a good clear picture, maybe I can be of more help.
