Coil Spring Install Problem
Old Apr 4, 2012 | 09:11 PM
Dycrow27's Avatar
Dycrow27
Default Coil Spring Install Problem
I have got to installing my new 2500 cummins coil springs and i had to cut torch bolts off of shocks and i finally got them off and the springs out. The PO had installed coil spring spacers and i no longer have the coil spring ?Insulator? and ?Mounting Ring with the studs? i believe that's what they are. So is this all i am most likely missing and were can i get them i have looked on auto-zone and no luck will i probably have to order them? Thanks in Advance
Old Apr 4, 2012 | 09:18 PM
Matt Nickerson's Avatar
Matt Nickerson
RockAuto has the 'Coil Spring Insulator-$10' and 'Coil Spring Seat-$20' <--or as you refer to it the mounting ring w/ studs.
The cummins, V8, and V10 parts are all interchangeable for these two things^^
Old Apr 4, 2012 | 10:16 PM
Dycrow27's Avatar
Dycrow27
Thanks for the input i found this would this be all i need? It looks like both
http://shop.advanceautoparts.com/web...RPSHOCAMS_____
Old Apr 5, 2012 | 01:38 AM
Ramcountryboy's Avatar
Ramcountryboy
Yep, that looks like what ya need, ring and insulator there... I'd check out the junk yard but thats just me
Old Apr 5, 2012 | 08:14 AM
Dycrow27's Avatar
Dycrow27
i would but I'm not 18 and i don't have my license and i would have to rely on someone else :/ and it would be my luck i couldn't get shock bolt out again to get coils out.
