I need help with a shifting problem - Ram 2500
Dodge Ram truck 2500 5.9 gas. shifts like .. from 1-2 most times shifts okay but there are times that I have to manually put it in 2nd and with RPM less than 2,000 it will shift to 2nd. And then from the 2-3 the same things RPM has to be less than 2000. not all the time but many times. It will shift to 4 only if its accelerating smoothly. 2 years ego I replaced the shifter selinoid. The trani was doing its job for less then 2 years about 20000 miles.
Any thoughts??? selinoid ? band adjustment?
