5.9 to 5.2 Swap PLEASE HELP
Old Apr 8, 2012 | 03:38 PM
dodgeboy2012's Avatar
dodgeboy2012
Default 5.9 to 5.2 Swap PLEASE HELP
I need some information to see if this is possible. I have a 2001 Dodge Ram with 5.9 that is bad. I also have a 94 dodge with 5.2. I would like to know if it is possible to swap these and what all may be involved. The 2001 has a new computer and I was hoping I can still use it. Any and all info would be greatly appreciated.
Old Apr 8, 2012 | 04:13 PM
dlyter09's Avatar
dlyter09
I wouldn't downgrade to the 5.2 I mean don't get me wrong its a great motor and all but it will be more of a hassle than its worth IMHO
Old Apr 8, 2012 | 04:26 PM
stewie01's Avatar
stewie01
Plus the '94 5.2 is OBDI and your 2001 is OBD 2, and there should be some difference's in the connector's for the transmission? over the year's.
Old Apr 8, 2012 | 04:35 PM
dlyter09's Avatar
dlyter09
Yea and I believe there is something with the egr and emmisions different.
Old Apr 8, 2012 | 04:37 PM
TC3EMTB's Avatar
TC3EMTB
Swap the intake manifold from the 01 to the 94. All the sensors, and then do the swap don't change the transmissions though.
Old Apr 8, 2012 | 06:30 PM
Wombat Ranger's Avatar
Wombat Ranger
Your '94 had EGR, but you will be using the '01 intake, so it is a non issue. Just use the 01 passenger side exhaust manifold (from the outgoing 360), and you're golden. Also, make sure to use the flexplate from the 5.2, not the 5.9. 5.9's are externally balanced, so the flexplates (or flywheels) do not interchange. The '94 5.2 will bolt up to the '01 transmission.
I can't say 100% for the computer, but if it were me I would try running the 5.2 on the 5.9 computer, I think it should work fine.
Old Apr 8, 2012 | 06:33 PM
dlyter09's Avatar
dlyter09
Id still be looking for a 5.9
Old Apr 8, 2012 | 06:54 PM
Wombat Ranger
With a free 5.2 layin' around I wouldn't...
Old Apr 9, 2012 | 08:06 AM
COL's Avatar
COL
Sell/trade the 5.2 for a 5.9. I would keep the 5.9 if i could. But with some major swapping Im sure it is possible. As for the 5.2 running on a 5.9 CPU...it may or may not work.
