Mopar Reman 5.2L Longblock
Hello All,
I have a 5.2L Mopar Reman Longblock (http://www.moparmotor.com/product/R2852480.html) that I was able to pick up at a very reasonable price. It's unused, 0 Miles, though has been sitting for about 3 yrs.
This brings me to a few questions for you guys and gals...
-Are there any problems associated with this sitting? It was sprayed with WD40, kept in and on plastic bags in a storage rental unit.
-Are there any particulars of this engine that are either good or bad? I have a 5.2L in my Ram now, and want to build or tweek this longblock to replace the current engine as she is beginning to "get tired". Nothing major, and she may have many miles left in her, but I figure I am keeping the truck, so I'd rather take this on before my backs against the wall.
Maybe mild performance upgrades or changes to improve MPG?
All advice is welcome, as I am not too much of a mechanic
provided the engine has been kept dry, and the cylinders are not rusted up, it should be a fine new engine. if you continue to store it, i'd fill each cylinder with a cup of oil rather than the wd40, then spin the motor 1-2 revolutions (some oil might dump out) and then put the spark plug back in keep debris out.
you should remove the intake and replace the plenum belly pan with the aluminum plate before installing it.
1.7 roller rockers and either a superchips or SCT tuner will give it a little boost and correct your death flash programming.
nothing improves MPG other than a good running engine, and modest sized tires.
