abs wheel speed sensor help!!!
Old Aug 15, 2005 | 01:24 AM
crusher135's Avatar
crusher135
Default abs wheel speed sensor help!!!
well, my abs light was on when i got the truck so i read the forums and it said it could be the sensor on the back axle well today i replaced it and the fluid's well guess wat!!!!!! it didnt work light is still on i even tried taking off the power cable on the battery but didnt solve anything and now my spedo is like reading 20 when im doing 10 lol i do have bigger then stock tires but it didnt do this before?
Old Sep 5, 2005 | 10:27 PM
dodgegirlsboy's Avatar
dodgegirlsboy
Default RE: abs wheel speed sensor help!!!
I have the same problem but the brake light and the ABS light are both on. Where is the sensor located
Old Sep 9, 2005 | 08:59 AM
fews's Avatar
fews
hello,
I had the same problem on my ram.
reason was a damaged wire from the brake very dispenser (i hope thats the correct translation) .
i repaired that wire and everything's ok now
hope to be useful
fews
