Overheating with all new parts
Old May 11, 2012 | 01:17 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
+1. Flow means nothing. It only takes a small amount of blockage to raise the temp. Kind of like the heater core (good flow but no heat) And what brand T-stat are you using?
Edit: BTW, the thread title could use help next time. As "all new parts" is not very accurate.
Old May 11, 2012 | 02:21 PM
  #22
Kurgen's Avatar
Kurgen
How about mostly new parts? Anyway, I just picked up a failsafe 195 and will install tonight. The one in there now is the brand from Advanced Auto. Dont recall the name.
Hard to check the radiator flow as I am pretty convinced I am not getting any return through the top hose. I ran the engine to a temp of around 225 per the guage and the water in the radiator at the top was cold to the touch with no increase in temp of the upper hose. I would expect to see some return hot water coming across the top of the radiator.
My next step in conjunction with changing the tstat again is a complete flush of the system. Planning on checking the tstat prior to install this time.
Will report back following all this. Thanks again for the thoughts.
Old May 11, 2012 | 02:27 PM
  #23
zman17's Avatar
zman17
First problem, "I just picked up a failsafe 195 and will install tonight" . Good luck, people in previous posts said don't use one. I for one agree.
Second prob. "Autozone" t stat . Nuff said, good luck bro.
Old May 11, 2012 | 04:21 PM
  #24
Kurgen's Avatar
Kurgen
Thanks for the feedback. I reviewed the FAQ's and found a couple folks happy with their failsafe tstats so I went that route. I did see the negative comments on them on this thread, but no suggestions as to alternatives. I was planning on testing it prior to install. What brand would you suggest?
Old May 12, 2012 | 05:26 PM
  #25
peshewa's Avatar
peshewa
The failsafes have worked well for me so far, but I am not everybody. I would leave the thermostat out then burp it & run to see if it runs cool. That will tell you if the thermostat is bad or not. If you live in the hot south, go with a cooler unit but here in Iowa, I stick with the 195 or freeze my tuckus off in the winter months. There are flush additives you can add then run for a while before doing the flush. I have never used them, so I can not validate the goodness of them. I would imagine leaving the T-stat out whil you flush would only be a good thing. And Zman17 is right, flow is not everything. A flush at this time seems like a great idea to me.
Old May 13, 2012 | 01:04 AM
  #26
johnnyjaws98's Avatar
johnnyjaws98
take your t stat out put it in a pot of boling water and watch it open up if it dont its no good!
Old May 13, 2012 | 01:36 PM
  #27
Augiedoggy's Avatar
Augiedoggy
he said advance auto which sells STANT brand not autozone...
I agree though failsafes seem less reliable than the regular ones...
Old May 14, 2012 | 11:09 AM
  #28
Kurgen's Avatar
Kurgen
Guys,
All great info. I did everything suggested, basically. I pulled the hoses and flushed the radiator to see how it flowed, I hosed it through from both sides, I pulled the tstat and flushed the engine. All this was good. I boiled the Stant and Failsafe and found the Stant not opening much at the temp where the Failsafe was wide open. I even stole one of my wife's cooking thermostats and checked the water temp when it opened. It was right at 195.
I put the Failsafe in and gave it another run with clean fluid at 50/50. Turns out, one of the issues I had was the guage on the dash is reading over 200 when the tstat opens. The needle is on the second "0", but I did verify hot fluid in the radiator and the top hose heated up. It held temp there, so I will go with that. I might run over to Dodge for a new sensor and see if it fixes the guage issue. Prior to the waterpump failure, it ran at 200 straight up, as I have noticed others do on the forum.
Anyway, thanks to all for the input.
Old May 14, 2012 | 01:39 PM
  #29
zman17's Avatar
zman17
Ooops! Read too quick.
On a side note, to the OP. Did you test the 3.99 stant or the 9.99 stant super stat?
Old May 14, 2012 | 01:44 PM
  #30
Augiedoggy's Avatar
Augiedoggy
Guys,
yup my gauge says 200 with a 2tant 195 stat..(cheap one) .. sometimes it gets up to 205...when I had my 180 stat installed it ran about 189 at the hottest according to torque app.
