random question
Old Aug 17, 2005 | 02:50 AM
Tani1500's Avatar
Tani1500
Default random question
I was looking around and i always notice some rams are lower then others. what were the options with the hights and things like that. i know the offroad is 2in higher then my truck but then i seen these trucks that are alot lower then mine. ( mines a sport ). ive just always wondered that.
Old Aug 17, 2005 | 07:20 AM
dodgekid's Avatar
dodgekid
Default RE: random question
I've got a 2WD Sport. It is probably one of the lowest non-special edition Rams that is currently stock. No I don't care, no I'm not gonna lift it. I know there was a package called 'Offroadster' for the 4WD Sport models. I know also that there wer many variatons a trim level. There's alot. One thing that obviously makes a diff in ride hieght is whether it is 2WD of 4WD. Obviously a 2WD will certainly be lower, unless you decide to lift it. Which is beside the point.
Old Aug 17, 2005 | 02:09 PM
minex's Avatar
minex
I also noticed that the 4X4 2500 seems higher than the 4X4 1500.
Old Aug 17, 2005 | 02:18 PM
dodgekid's Avatar
dodgekid
it is.
Old Aug 17, 2005 | 04:24 PM
V10's Avatar
V10
The last time I was at the dealer, they had two `05 3500 4x4 Cummins Quad single rear axle shortbox sitting side by side with nearly identical options on the window sticker, including snowplow package, and there was a 2" difference in height between them.
Old Aug 17, 2005 | 06:57 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: minex
They are. The heavy duty trucks (2500/3500) had larger and heavier (read stiffer) springs. And if you have a V10 or a CTD, you're way up in the clouds. [8D]
The snow plow prep package, camper package, off-road package, towing package, and tire option all influence the height of the truck.
