Transmission not shifting
Old May 13, 2012 | 10:49 AM
stana1's Avatar
stana1
Default Transmission not shifting
I have a 97 Dodge 1500 2wd 318 engine.
The transmission when in drive starts off in third gear.
I can manually shift to 2nd and it will take off in second and I have to manually shift to drive or 3rd.
I have no low gear automatically or manually.
I do have overdrive and converter lockup.
The kick down cable and spring are intact and adjusted properly.
Anyone have any suggestions?
Thanks.
Old May 13, 2012 | 11:05 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Try checking for any stored codes, http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
and this may help https://dodgeforum.com/forum/2nd-gen...agnostics.html
I'd also pull the pan and see what it looks like in there.
Old May 21, 2012 | 05:10 PM
stana1's Avatar
stana1
Default transmission not shifting
Thanks for the info. replaced the governor solenoid and relay and everything is ok now.
