Hey I've got a 99 Ram with a 5.9 Gas motor. I have a P0505 code with a CEL on and for some reason the gas gauge doesn't work when the light is on. My Idle is fine even with the AC on or in gear. I checked the IAC plug with a test light and the key on. Nothing from Ground to the plug on all four wires. From Power to the plug the light is on at all times on all four wires. Seems like the computer is grounding inside?? any ideas?
Replace the IAC, . If that doesn't work sorry for wasting your money. Remove the negative battery cable before replacing or cleaning it if you decide to do so.
