P0300,0301 and 0304 codes
Old May 29, 2012 | 02:41 PM
robsmith1964's Avatar
robsmith1964
Default P0300,0301 and 0304 codes
Stopped at a red light yesterday and noticed that the truck was running rough. Kinda sputtered when i took off. Went to cross an intersection and it chocked out and almost died. If I try to give it to much gas it sputters and pops. Then it popped a p0300,p0301 and p0304 code. Any clues?
Old May 29, 2012 | 03:04 PM
Ramzy's Avatar
Ramzy
Hello and Welcome to the forum!
Misfire codes for multiple misfires detected and those two specific cylinders. Check plugs, wires, and plug wire routing according to TSB which can be found in the DIY section. Also read the stickied plenum thread at the top as this causes the majority of our issues. Also the bogging down when trying to accelerate can be due to a clogged cat which is a result of the blown plenum, it can also cause misfires. A clogged cat can eventually cause a cracked head to occur. Take your time reading the plenum link. I think you will find some good info there.
Once again, welcome!
https://dodgeforum.com/forum/2nd-gen...um-thread.html
https://dodgeforum.com/forum/2nd-gen...lug-wires.html
EDIT: Also grab the factory service manual from the FAQ, DIY section. As a note, it always helps to give the details of your truck so that we can help you in the most effective manner possible.
Old May 29, 2012 | 03:10 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Judging how it is a 304 and 301, I would say the plug wires have failed and are not routed properly.
Try doing a full tune up and route the wires per the TSB Ramzy has posted there.
WELCOME TO DF!
