Time for a clutch
Old Jun 29, 2012 | 07:12 PM
mccart's Avatar
mccart
Default Time for a clutch
Well my clutch is starting to slip in my truck. It's a 318, what clutch do you reccommend? My dad had a Sachs in his which is the same truck as mine and the springs/pressure plate came apart after about 20k miles. I'm looking at the centerforce I series if it's worth it. I can get one from o reillys for 190. And is it a 12 inch or 11 inch clutch?
Old Jun 29, 2012 | 08:03 PM
Hahns5.2's Avatar
Hahns5.2
I run a OEM Valeo in my truck. The disk I just pulled out only had .015" total wear in 61k miles and it didn't slip behind my ~440ft/lb turbo motor. I put another one in it since I had the motor out, new one doesn't slip behind my new, more powerful setup either.
Old Jun 29, 2012 | 11:28 PM
mccart's Avatar
mccart
Is it a 11 or 12 inch disc
Old Jun 30, 2012 | 03:50 PM
Hahns5.2's Avatar
Hahns5.2
My disk measures 11 7/8".
Old Jun 30, 2012 | 05:15 PM
Wombat Ranger's Avatar
Wombat Ranger
11" factory, up to 12" fits on the stock flywheel with no modification. No reason not to go bigger. I have a kevlar clutch. It's smooth unless you like to take off without any throttle input (like me...) then it shudders a bit. I like the clutch a lot. But it's overkill for my current setup. And it wasn't cheap... I paid $412.
