Dana 44 2500 light duty and 5 and 8 lug rotor info and discussion
The op hasn't been here since: Last Activity: 08-01-2012 02:11 AM
And this post would make the most sense if you want to do the conversion. Not to mention the master cylinder is a different size.
He has a point though..... If you wanna go with larger tires, (35+) the 44's just aren't going to cut it. You could probably find a front D60 for less than what you would spend to convert the 44 to eight lug.....
