How hard to replace AC Compressor on 2000 Dodgem Ram 1500?
Old Jul 8, 2012 | 12:35 AM
daytraderbm's Avatar
daytraderbm
Default How hard to replace AC Compressor on 2000 Dodgem Ram 1500?
How hard to replace AC Compressor on 2000 Dodge Ram 1500? Seems pretty simple. Let the freon out, take Belt off, unbolt 4-6 bolts, unplug all of the wires, install new compressor, hook up wires, put belt back on, recharge system. Anything I'm missing here? Seems pretty straight forward.
Old Jul 8, 2012 | 12:45 AM
merc225hp's Avatar
merc225hp
It is straight forward, but a shop should remove the refrigerant and recharge the system. It should not just be released into the air.
Old Jul 8, 2012 | 12:47 AM
daytraderbm
I have a small reclaim tank that is plenty for this job. First time I'll be able to use it!
Old Jul 8, 2012 | 12:56 AM
gdstock's Avatar
gdstock
Do not forget tro pull vacuum on system after connecting it all back up, and adding oil to the system when you start to recharge. I let it sit with a vacuum overnight if I can to make sure system is tight.
Old Jul 8, 2012 | 08:38 AM
daytraderbm
Thanks for you help! Going to try to get it all fixed back up today. Hope I can finally get my AC back working after 16 months lol
Old Jul 8, 2012 | 09:00 AM
SilverSS's Avatar
SilverSS
Make sure to get a new receiver/drier and flush out the lines with a cleaner. There may be further instructions that come with the compressor that are required for a warranty so do those too. If you don't have recipes for them the compressor manufacturer will not warranty it.
Old Jul 8, 2012 | 11:31 AM
ryan0714's Avatar
ryan0714
take the belt off, take the lines off the top of the compressore, take the 4 bolts out that hold the compressor, undo the eletrical connector, and then ur dont i think if i remember right.
