advice on removing seized steering shaft?
Old Jul 18, 2012 | 04:57 PM
korecoa's Avatar
korecoa
Default advice on removing seized steering shaft?
bought the rock solid steering bushing, but i can't get the steering shaft to telescope to remove it. I was able to get the pinch bolt out but it will NOT slide down. i've hit it with penetrating oil and tried to tap it down and pry on it with a pry bar but nothing is working. today i'll try from the bottom end but thought i'd get some more input to see if one of you guys has a trick to it.
