94 ram 1500 4x4 5.9 - Vehicle will not idle, will turn over but won't run.
Old Jul 25, 2012 | 12:25 PM
fromthisdesk's Avatar
fromthisdesk
No codes? Well -- I had something similar where the engine would die at idle and it was the TPS. A $30 part. If you do pull the IAC, you need to be very careful cleaning it. Otherwise, another $30. If it needs a tune-up then you should get one - plugs, wires, distributor cap/rotor you can do yourself for $60 or so.
Old Jul 27, 2012 | 07:09 AM
2 Marks's Avatar
2 Marks
I had the same problem last week. Engine died while driving... it was the coil.
Old Jul 27, 2012 | 11:59 AM
TheBullRoars's Avatar
TheBullRoars
With these bitches its best to get the highest quality wires sensors etc possible
