Truck dies while driving then won't start right away
Alright guys I have a 99 dodge ram 1500 5.2 5 speed. I'll be driving down the road and the truck will just turn off and won't start back up for about 5 mins. The truck turns over but it's not firing. I've swapped out the ASD relay and it's still doing it. When the truck turns off the gas gauge, battery and temp gauge aren't reading anything. Any help would be awesome thanks!!!
Replaced the coil still the same any ideas guys? I'm thinking it's the computer....
After it quits the first time, how long will it last before it quits again?
Now this is most likely the crank sensor.
On a side note, I just noticed the OP started 2 threads about the same issue! WHY ?????
Some times it starts right up other times it takes about 5 to 10 mins
Seems like you'll have to try whats been suggested in your threads.
This is the only tread I've started. I was replying to heyyou's post. I've orded a crank sensor so I am trying everything bro.
Real sorry bud, if you look back a day or so, you'll see another Robert posted basically the same question on the same day as you posted yours. My bad, sorry again. ;)
It's cool bro
