Top shock nut
Old Aug 17, 2012 | 04:40 PM
3dubs's Avatar
3dubs
Well I rednecked it. I got some mule tape (Flat rope used for pulling cables underground) wrapped it about four times around the shock through the upper shock mount and then wove the tape through the spring so my son could hold it. Then I could could get the nut off. Of course I PB Blastered it when I first started.
Old Aug 17, 2012 | 04:41 PM
aofarrell2's Avatar
aofarrell2
There you go!
Old Aug 17, 2012 | 04:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yep, that will work too.
Old Aug 17, 2012 | 04:55 PM
3dubs's Avatar
3dubs
Originally Posted by techningeer
Any good shock will have a place for a wrench under the wheel well, i.e. where the spring meets the upper mount.
I have seen those on other shocks but these did not have that. Thanks for all the advice. I only had my eight year old son helping me so I other advice.
Old Aug 18, 2012 | 12:05 AM
CharlieSheenWins's Avatar
CharlieSheenWins
could've just taken the shock and shock tower out together and then loosen the nut. it was easy when I did it that way. Nice spring compressor btw wish i could've had one of those when I put my spacers in haha
Old Aug 18, 2012 | 06:52 AM
dhvaughan's Avatar
dhvaughan
^good suggestion on removing the tower first. you have to remove it anyway, so its no loss.
too late now, but if you can get to the top of the top shock cone, there's a nut there.
Old Aug 18, 2012 | 09:55 AM
3dubs's Avatar
3dubs
Not on the driver's side. The master cylinder, all the ABS stuff and wires are in the way. The instructions said to start with the driver's side but the passenger side is easier to see what was going on. If I would have started with the driver's side the neighbors would have called the cops because they would have thought there was a fight going on
Old Aug 18, 2012 | 10:22 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
the only way i did it was with an extra set of hands and it was hard then too but eventually came off.
Please keep the details of your sexual escapades limited to the General Forum
Old Aug 18, 2012 | 11:14 AM
aofarrell2's Avatar
aofarrell2
Yes there is a nut under the tower. I will post a picture on getting to it easily.
Old Aug 18, 2012 | 11:25 AM
95RAM360's Avatar
95RAM360
I have no problem getting a wrench right there...ive done the fronts twice on my 4x4 and once on my buddies 4x2...
