Reverse Slipping? (after heavy load)
Old Aug 22, 2012 | 05:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Change fluid , adjust band, clean gov solenoid while pan is off. You might get lucky who knows. If it works , delete check valve, install tranny cooler and tranny temp gauge.
Old Aug 24, 2012 | 02:19 PM
stewie01's Avatar
stewie01
So from a cold start I pretty much have no reverse, put it in "R" and it's just like putting it in Neutral.
I have a little after it's warmed up.
Question I have, if 1st and Reverse are on the same band, rear, and 1st is working perfectly, is there any reason to think a band adjustment will help, or am I missing something?
Old Sep 22, 2012 | 01:09 PM
stewie01's Avatar
stewie01
Alright guys, today was the big day. Dropped the transmission pan and here's what I found:
And the real kicker:
Is a band adjustment going to fix this or am I in for a rebuild?
Old Sep 22, 2012 | 01:18 PM
zman17's Avatar
zman17
You are in for a rebuild regardless eventually. I'd adjust the bands and hope to get some more miles out of it. Fluid and debris looks pretty normal depending on how long ago the tranny was serviced.
Old Sep 22, 2012 | 01:22 PM
stewie01's Avatar
stewie01
Ok. Transmission was originally rebuilt around 3 years ago, the previous owner had it rebuilt.
Old Sep 22, 2012 | 04:14 PM
stewie01's Avatar
stewie01
Alright guys, adjustment done and reverse is working flawlessly, wonder for how long though? Maybe time to trade her in....
Old Sep 22, 2012 | 04:24 PM
gdstock's Avatar
gdstock
Rebuild is not that bad. Parts from www.wittrans.com.
Old Sep 22, 2012 | 05:36 PM
dlyter09's Avatar
dlyter09
If you trade her in make sure and get yerself another 2nd gen... 4x4 though this time
Old Sep 22, 2012 | 05:49 PM
stewie01's Avatar
stewie01
There's one in town, private seller, same thing as mine, 2 tone white with greyish bottom, only, it would appear to be an Off Road Edition But I haven't stopped to look hard enough to confirm.
Old Sep 22, 2012 | 05:59 PM
dlyter09's Avatar
dlyter09
I say do it.. While the truck is running good take it down and trade it in
