Rear end swap
Old Sep 23, 2012 | 11:26 AM
ramthis9501's Avatar
ramthis9501
Just thought I'd update you guys...
The axle is installed and everything is working flawlessly! I am amazed at the difference in performance! Put it to the floor and it'll whip your head back
I knew the power was there, but just wasn't getting put to the ground with those wimpy 3.55's... Now... These 3.92's have unleashed the beast! It's also posi-trac, so it has unbelievable traction now!
Would I recommend it? Heck yes I would!! If you want some good performance gains, this is the thing to do, get you some 3.92's!
Old Sep 23, 2012 | 06:41 PM
Wombat Ranger's Avatar
Wombat Ranger
Where's the burnout video?
Old Sep 23, 2012 | 09:01 PM
ramthis9501
That's gonna be awhile... Lol waiting until my tires get bald, then I'll have some fun
Old Sep 23, 2012 | 10:12 PM
ryan0714's Avatar
ryan0714
glad you got it done, told ya it was easy...
Old Sep 23, 2012 | 10:48 PM
ramthis9501
Eh wasn't technically "easy".... Those drum brakes suck! It took forever to get them just right. Now that we put new brake shoes on it, they're rubbing the drums a bit, so guess I just gotta drive it until they get worn in good.
Old Sep 23, 2012 | 11:48 PM
gdstock's Avatar
gdstock
How far off is speedometer? Might want to check....before a trooper tells you!
Old Sep 24, 2012 | 09:16 AM
ramthis9501
Somehow its still spot on! I checked it with GPS at least a couple of times
Old Sep 24, 2012 | 09:30 AM
dhvaughan's Avatar
dhvaughan
the later models, i think 98+ take the speedo signal from the rear diff tone ring. this causes no speedo effect on a gear change, but it is affected by tire size.
the computer measures the revolutions of the rear end ring, and then uses revs-per-mile and time to calculate speed and distance.
the earlier models with the plastic gear in the transmission are affected by both gear ratio and tires.
- the simplest test for speedo accuracy is to run the highway at exactly 60 mph and verify you pass the mileage markers at exactly 60 second intervals.
