spark plug heat shields?
So I did an engine swap and left the heat shields off that go around the spark plug because there was a little dirt build up and I never realized all the dirt that got dropped down into the cylinders when I change them. The problem is that a buddy from saw that and said that i should put it back on because the heat from the exhaust manifolds could burn the wires. i also broke the clip that holds the wires together near the valve cover and I don't know if the wires touching the valve covers can damage anything?
i threw my heat shields far far away about 6 years ago with no problems. they trap dirt, make the plugs hard to change, and can contribute to cross threaded plugs.
its important to keep your wires up off the hot exhaust manifolds. you can get universal clips at any part store, junk yard. use wire ties or duct tape temporarily as needed. touching valve covers is not too bad, but better if they don't.
I tried to remove one of mine, and it didn't seem to matter how hard I pulled or twisted, it wouldn't budge. I ended up mangling it pretty bad, and had to straighten it back out so I could hook my plug wire back on.
Is there a trick or magic spell I have to recite to get them off?
i removed my plugs first, so i wouldn't risk breaking a plug. blow the tubes out with air before removing the plug so all the dirt doesn't go down in the cylinder.
i grabbed them at the top with a pair of channel locks and rocked them back and forth. some required twisting.
if they still won't come out, use a hammer to tap them back and forth.
if they still won't come out, use a chisel to crease them down at the manifold and reduce their diameter. be careful - don't break anything other than the heat shields.
How are they listed on E-Bay? Should I search for "Spark Plug Sock"?
Trending Topics
I should have said sleeves as that's what I searched for. Here's a link to a set similar to what I installed.
V10 plug sleeves
V10 plug sleeves
V10 plug sleeves
V10 plug sleeves
