No bus code
Old Sep 9, 2012 | 01:37 PM
Johnn123's Avatar
Johnn123
Default No bus code
Hey all, new ram just threw a code, no bus. CEL, abs and air bag lights are all on and there is no guages. Been searching around and have seen it could be the crank position sensor, a loose wire or ground, or a bad connection somewhere. What's the best place to start and what should I be looking for ? Anyone have this before? Thanks
Old Sep 9, 2012 | 01:47 PM
dhvaughan's Avatar
dhvaughan
loosen/tighten, clean the big screw down plug in the power box beside the battery
Old Sep 9, 2012 | 01:50 PM
Johnn123's Avatar
Johnn123
Ok ill try that thx
Old Sep 9, 2012 | 02:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Disconnect the battery before you clean that big plug, and clean/check the PCM connectors also while the battery is disconnected;.
Old Sep 9, 2012 | 04:40 PM
Johnn123's Avatar
Johnn123
Fixed it, seems to have been a bad ground on the pcm. Checked fuses first, all were good, disconnected battry, tightened the power box screw to no avail, cleaned pcm ground and that seemed to do it!
Old Sep 10, 2012 | 05:37 PM
zman17's Avatar
zman17
Thanks for letting us know the fix.
