Horn/Cruise-Clockspring?
Old Sep 15, 2012 | 01:01 PM
ronnyvous1's Avatar
ronnyvous1
Default Horn/Cruise-Clockspring?
My second issue with this 98 12V 2WD Cummins w/AT. The cruise powers up but won't engage, and the horn, initially, took some doing to hit the button "right", now its DOA, checked fuse/relay and horns themselves, all working. Feels like no contact or switching going on in there. I looked around a bit and the clockspring was mentioned in a few posts, is this a likely cuplrit for both problems? I did pull the cover and made sure the plugs were in, but didn't want to get too creative with the airbag in hand, even with batt's disconnected.
Old Sep 15, 2012 | 01:46 PM
ReadRam's Avatar
ReadRam
I had a no horn problem a few weeks back. Turned out the relay was good , but was not making good contact when plugged in. Gave the spades on relay a little bend, reinserted, had horn.
Found it out by dumb luck, wiggling the relay while holding horn down. Whether your two problems are connected or coincidental, I don't know.
Old Sep 19, 2012 | 08:51 AM
ronnyvous1's Avatar
ronnyvous1
Tried the wiggle trick, no good. I'm going to replace the clockspring and see how that plays out. If it doesn't, I see a horn button on the dash in my future...
Old Sep 19, 2012 | 09:33 AM
wjxavier's Avatar
wjxavier
i had a no horn and no cruise problem in mine for the longest time. it was the clockspring. had it swapped out, everything worked for a while, then my cruise quit working, but my horn was still good. doesnt bother me any lol, dont use cruise anyway
