how to test fuel pressure
Old Sep 24, 2012 | 03:54 AM
cutthroatxxx's Avatar
cutthroatxxx
Default how to test fuel pressure
Hey does anyone have a link or info on how to check my fuel pressure&injectors?I have a haynes manual bug my kids seem to of hid it on me
Old Sep 24, 2012 | 11:16 AM
ReadRam's Avatar
ReadRam
Not sure if 95 has spot on fuel rail to hook up gauge. Drivers side. can loan from auto part store.
Old Sep 24, 2012 | 11:54 AM
cutthroatxxx
There is it looks like a tire stem head.
Old Sep 24, 2012 | 12:19 PM
gdstock's Avatar
gdstock
Fit gauge onto that shreader valve. Crank up and see what you get.
Do you have the FSM that can be downloaded form the FAQ/DIY section? Harder for ids to hide that! (my grand daughter used to hide my son's keys....so he would not leave to go to work! He found them in the darndest places!
Old Sep 25, 2012 | 10:46 PM
cutthroatxxx
thsts funny. on via my phone so that would be a lot of memory What gauge?It looks like a tire stem
Old Sep 25, 2012 | 11:19 PM
DodgeRam10's Avatar
DodgeRam10
fuel pressure gauge will have a fitting to screw on there. Check pressure with key on but not started,than check with it started,find the fuel regultor and pull the vacuum line off while its running and pressure should jump up,if not regulator is bad.
Old Sep 26, 2012 | 06:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is no vac line going to fuel pressure regulator!
And to cutthroatxxx buy another Haynes when you go get the $25 fuel pressure tester.
