power steering leak help
Old Sep 26, 2012 | 09:11 PM
bwacked's Avatar
bwacked
Default power steering leak help
1998 Ram 1500 5.2 4x4....I noticed the high pressure power steering hose was leaking where the pressed fitting is, I replaced the hose, and again that new hose is leaking in the same spot. what gives? thx
Old Sep 27, 2012 | 11:35 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Are you talking on the pump side or gear box? Leaking both ends? I'm not sure what you mean by "pressed fitting" other then NOT the threaded fitting.
Did you remember to place new o-ring on the fitting of the hose? You gotta also get that bugger on real tight!
Old Sep 27, 2012 | 12:06 PM
Sooper's Avatar
Sooper
Agreed. Also make sure the old O-ring isn't down inside under the new O-ring. They do tend to stick when the fitting is removed and both O-rings in there will cause a leak.
Old Sep 28, 2012 | 05:04 PM
bwacked's Avatar
bwacked
thx for the replies, i checked with my mechanic and he says its a manufacturing defect. I did install new o rings, it's not leaking from the threads on either end, one end has a pressed fitting just after the thread. it's where the metal tube comes out of the fluid filler and changes to the rubber hose. thats the fitting thats leaking..guess i gotta get a higher quality hose and try again.
Old Sep 29, 2012 | 01:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What brand did you purchase?
Old Sep 30, 2012 | 01:32 PM
bwacked's Avatar
bwacked
zman17 i bought it from autozone i think it's the duralast brand, anyway i got a new one from napa today, lets see if it holds this time. Napa brand was only $1 more in price
Old Sep 30, 2012 | 01:47 PM
zman17's Avatar
zman17
Somehow I knew you got a duralast. Hope it works for you this time
