Headers question
Old Oct 11, 2012 | 09:04 AM
drewactual's Avatar
drewactual
as J4 said, in stock condition, there are no exhaust manifold gaskets.. it's steal on steal..
Old Oct 11, 2012 | 10:27 AM
Arde's Avatar
Arde
Originally Posted by Derick C.
Exhaust manifold gaskets. Header gaskets always seem to leak.
I always heard it was the other way around. That header gaskets were thicker therefore less likely to leak. It used to be recommended to soak the header gaskets in water before installing for a better seal. Don't really know if that's still the case. They might be made of different material than they used to be. Last set of headers I installed was long ago so haven't really kept up on it.
Old Oct 15, 2012 | 09:48 PM
Blue Mopar01's Avatar
Blue Mopar01
Sorry to bring up an old post but I have 2 quick questions, is the gaskets that come with Pacesetter headers good or do I need diff. ones? And is the difference in performance or anything between an offroad y pipe or a Magnaflow y pipe?
Old Oct 17, 2012 | 10:35 PM
Blue Mopar01
Bump..does anybody have some incite? I liked to have the right stuff the first time around.
Old Oct 17, 2012 | 10:39 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by Ram It Hard
1.Are headers worth it?
2. Does anybody have trouble w/ them warping or having to keep tightening them?
3.If I do go with them, what ones do I go with(under $500).
NO
ALWAYS. also rust.
DON'T. then you have to do custom exhaust, and then you run out of room for pipes, and have to turn them out to the passenger side, or dump them down
Old Oct 18, 2012 | 08:38 AM
Blue Mopar01
I already have a custom exhaust though?(just no headers..yet) And have room for extra pipes, still wondering on the offroad y pipe and just a y pipe.
Old Oct 18, 2012 | 08:54 AM
drewactual's Avatar
drewactual
I used to have a picture laying around, but I've lost it.. you'll want the pipes junction restricted as little as possible.. the OE Y is a joke, choke central... the off road Y isn't mechanically obstructed like the OE..
insofar as gaskets- I played hell for a long time.. it's been a good long while since I've had issues, and it's because I did what I knew I should have done in the beginning- I went with Remflex gaskets and stage8 locking bolts.. problem solved..
stage8 bolts: ~$50ish
Remflex gaskets: ~$50ish
it was well dang worth it..
all that said, the headers isn't where I found gains.. removing the factory Y is where I found gains..
Old Oct 18, 2012 | 10:43 AM
Blue Mopar01
Huh I see, would that Magnaflow y pipe do the trick too for replacement of the OE y?
Old Oct 18, 2012 | 10:49 AM
drewactual's Avatar
drewactual
anything other than the OE is better...
Old Oct 18, 2012 | 10:59 AM
Blue Mopar01
Thanks for the info! Just one more, where did you get the remflex gaskets at?
