Old Aug 7, 2015, 02:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exhaust and Intake System
Print Wikipost
IAC idle air control valve keeps going bad
Old Oct 11, 2012 | 07:17 PM
boostintt's Avatar
boostintt
Default IAC idle air control valve keeps going bad
1999 dodge ram 1500 5.2 200,000 miles auto
i first replaced the iac about 4 months ago after owning the truck for about 4 years.
Truck did not want to idel today, replaced the IAC again and its fine.
what could be causing the IAC to go bad?
thanks.
Old Oct 11, 2012 | 07:20 PM
crazzywolfie's Avatar
crazzywolfie
have you tried cleaning them and the throttle body?
Old Oct 11, 2012 | 07:43 PM
UnregisteredUser's Avatar
UnregisteredUser
Did you buy the first replacement from Auto Zone or another one of that sort? If so, that's the reason for it failing so soon.
Old Oct 11, 2012 | 08:55 PM
boostintt's Avatar
boostintt
i havent cleaned the tb or the carbs..
i bought this $43 part from advanced discount auto parts and i told the guy that i had just bought the same part a few months back.. he obviously blamed the carbs being dirty and not the part being faulty.
i just want to make sure its not the part so i can buy an OEM one this time and im still going to clean the tb and carbs.
Old Oct 11, 2012 | 09:24 PM
dhvaughan's Avatar
dhvaughan
i fought a period of what i thought was bad IAC's. turned out to be a bad TPS. there can be strange interaction between them. IAC doesn't kick in unless TPS says its at idle. TPS can also cause surging idle RPM.
sometimes PCM reset helps things and makes you think the IAC swap helped.
DO clean the IAC port on the back of the throttle body, at the end of the IAC well. also clean the well so the pintle can seat properly. i think cleaning the rest of the throttle body is not so important, other than a general cleaning with brake or carb cleaner.
Old Oct 11, 2012 | 11:44 PM
horatio102's Avatar
horatio102
You've got a throttle body AND multiple carburetors?
Old Oct 12, 2012 | 02:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yea, the IAC can't handle all 3 of those things at once. Anyway, here's a DIY on how to clean the throttle body and IAC. Just make sure you remove the negative battery cable before doing so.
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Oct 12, 2012 | 09:49 PM
aofarrell2's Avatar
aofarrell2
Carb on 1999 dodge?
Old Oct 12, 2012 | 10:11 PM
gdstock's Avatar
gdstock
Originally Posted by techningeer
Carb on 1999 dodge?
Yep. Clean TB per instructions. Take it back and ask for your money back and tell the fool that it is Fuel Injection and there is no carb. (I would go in and ask for a carb just to see what the fool would do....)
